- Thread starter
- #16
Thanks Alan, will the 5v drive the Pi as well? I will still need to fuse the 5v input line with a 2a fuse correct?I hate being called a newbieIt is my mistake though. The diode D1 is inserted back to front.
This diode is to protect the board and Pi if the 12V is put around the wrong way.
The good news is that the board will work fine on 5V if you have it on that power board or if the diode is bridged out with a wire link or swapped around.
You can still run 12V pixels when running the board off 5V. There's 4 separate power inputs for the 3 pixel outputs and the board+pi.View attachment 20940
