Guys, i have put together a 1 pager to help people understand the different uses of the 44 controller and the many ways it can be configured. It should go a long way to helping people understand the many different choices available with the 44 project
I have also added a resistor value calculator to help you work out the required resistor values needed to be used on the 44 boards based on the conditions you set.
If your not sure the 44 project is done by a member mrpackethead and all information and queries can be done through his web site at http://www.dec1.org/forums/index.php
