BundyRoy
- Apr 9, 2014
Last night I had 3 outputs of my ECG12x working with DA_131. I just used the rgb/single tab and used the single slider to put everything on full white and left it running for about 10 minutes. When I tried to turn it off with Da_131 I just changed the slider to 0 but only 1 of the three outputs turned off the other 2 stayed on full white. I have a separate lights network card on my computer and I have the controller directly linked (ie no switch). I was using unicast. Does this indicate some sort of issue I should be worried about with the controller or is it just one of those things. I had been mucking around earlier and had been turning them on and off in the other colours but I hadn't let anything run for any length of time. I had about 250W of pixels running on a 350W power supply (same supply ran the controller 2). I even measured the power consumption through the power point as a check. The pixels are ws2811 nodes and I have them set at a speed of 3200.
Am I using Da_131 correctly or do I need to change some settings there.
