It doesn't seem to matter if it's in test mode or not. Any time the sequence is idle, the light flash. The flash does not appear to be full brightness.
Is it all pixels or just a couple? If just a couple could be dodgy pixels. Otherwise maybe try playing with the speed in your p12r config. Change up or down and reboot.
I have a string of 25 pixels attached and all of them flash. They may be doing it when the sequence is running also, but it isn't noticeable then. I'll try changing slots and strings tomorrow to see if that has any effect.
2 points to check :
a) Distance from controler and first pixel of your string (as far as I remember 6 meter max, without any repeater or null pixel)...
b) The speed is to high on your settings... change the values down until you get a stable display
Im not gonna be much help but I think there was someone a couple of weeks ago in chat who was having a similar problem, turned out to be the ground? Im not 100% sure how it was fixed, but thought I would throw it out there.
Last season, I had a 'flicker' that would show up on my strips around 2 windows (taped to alum window frame)
I would change them and it would fix it. But when I'd take the old strip and test on the workbench, it would be fine. I kept thinking it was a ground problem. Right before the end of the season, I switched to a higher power FM transmitter, which is just inside one of the windows. As soon as I'd turn it on, the flicker would start. Shielding the short wires between controller and strip didn't help- as the whole strip has conductors and IC's that are exposed the whole length.
