Dave H
OK, originally had problems with my P-2 but was found that it was a bad Ethernet chip which Ed replaced. (that was a previous post from last month) Great customer service from J1SYS right before Thanksgiving!!
However, I am still having issues controlling the P-2 through LOR. I’ll try to provide the current overview:
Could not run the P-2 in Xlights while in multicast. Switched to unicast and all test patterns contained in Xlights work; and
· Converted the LOR test sequence to a Xlights sequence and the test sequence runs in Xlights (under unicast only).
Now back to LOR
· USB-485B connected and open control panel. Com listener recognizes universe 1 and is “listening on port 5568”
· Under network preferences I have both the DMX listener port and E1.31 port set to 5568 (have tried this both with multicast and unicast 10.10.10.10);
· All of the 50 channels in the sequence are pointing to universe 1; and
· Click play (ensuring control lights is checked) and…………………………..NOTHING
Where am I going wrong??
Fortunately I am not doing a show this year so I am not pressed to get this resolved immediately but would like to be confident in being able to run some pixels next year.
- Installed a separate Ethernet card in computer specifically for E1.31 use;
- Connected to a 4 port switch which is then connected to the P-2;
- Can connect to the P-2 using the default 10.10.10.10 address. There is one string of (50) WS2811 pixels connected and they cycle correctly through the test pattern; and
- Created a short 45 second test sequence in LOR S3 – nothing worked (I’ll circle back to this).
Now back to LOR
