AussiePhil said:zman said:Ed,
Any update on the availability of the ECG-P2 and X2 hardware?
I plan on building a 16 universe RGB Tree this year. If I have understood everything correctly, to accomplish this, I would need 3 of the P2 and 2 or 3 the X2? That would give me some head room to spare. Can you clarify? Thanks.
Z,
One thing to consider is the trade off between the number of pixels you control and the risk of losing that entire string in the display due to a pixel failure.
Typically we have seen in the past a controller output controlling 50 to 100 pixels with some people running maybe 150.
Now as pixels are a repeated serial protocol the failure of a pixel early in the string would take out that string of 50/100/150 pixels, with maybe not a noticeable lose on the night.
Now drive 600 pixels from the same single output on a ECG-P2 because we can then the failure of a pixel could take out a 1/4 of 2400 pixel megatree.... this you will notice.
Now if you have confidence that pixels won't fail and accept the risk then all's good, just wanted to flag the risk.
Phil
I would think that the ECG-P12R or the ECG-PIXAD8 would be the best choices for a mega tree, you get fused protection and easy distribution. I reakon these controllers are ideal for mega trees and matrices.
The reason for my thinking is for a localised element like a mega tree or matrix then using multiple outputs eliminates the potential issue that Phil mentioned above and gives you fused protection. But on saying this there is nothing stopping you using the P2 or the X2
