danv said:Also going to knock up another board that is very similar, except it will have a couple of WS2811 IC's on board with FET output stages so I can drive dumb RGB elements![]()
marmalade said:most rgb dumbs run @ 12V so you need a resistor on the VDD of the 2811.
leave fuse off IMO.
but otherwise...
David_AVD said:A bit of deja vu reading these last few posts. I did some little 3 channel DC boards a few years ago to suit 6803 or 2801 systems.
They are certainly handy for when you want to use a DC element (star topper for example) as part of a megatree or similar.
Sounds like Dan is well on the way to making some handy little boards.![]()
| Received | Sent | |
| Bytes: | 3,116,794 | 2,511,702,467 |
| Packets: | 10,960 | 4,615,180 |
