Extension leads
Anastasia sidiropoulos
Anastasia (Stacey)
Melbourne
Good evening all
It’s been a little while since I have been on this forum. But it’s that time of the year again and I am needing some help with trying to find someone who supplies extension leads for fairy lights. I have plenty 10 meter extension leads for light sets with the round socket used up until 2017. As of last year the plug ends have changed to a screw on type with two pins. See images attached. And the length of lead from lights to transformers has reduced significantly. Meaning I can no longer get a line to the house or power stations set up around the display.
Hoping someone can help.
Kindest regards
Anastasia
Bite my shiny metal ass!
You may be able to get extensions for the round plugs, but the 2-pin will be unlikely.
Ideally you'd be better off learning to solder so you can repair and extend the leads you have.
OzAz
Newcastle
What David said, but if you don't want to solder there are several alternatives
Butt crimp connectors with sealant
Butt solder connectors with sealant
3M Scotchlok connectors
