f16 V5 Ports Not working
LongLights25
helloo
i am stuck iim using a falvon f16 v5 ,i have 12v going to the board but i seem to only have ports 9 to 13 only woking as i have tried with trying to add but thay just wont work i have cheked and resetted the fuses and on the thing it shows that thay are good so as i can only run show off 4 ports
any help appreactated ?
bassically i used this last year and cant remeber if iwas the same , but ive only used v2 and that had just as many props/ pixels as im trying now , i thought it was the wireing but if put the same pixrls in the working ports and it woks but from 14/16 nothing
i know that i want to use 14 to 16 but thay just wont work , whats latch chips ?
do u have f16 in test mode , when checking the port output
yes i had it in test mode and does nothing i plugged the same pixels into th oring port with same pixels and thay work , ive got a feeling somthing wrong with the board
