Faces in xLights sequence
Jorge Bolivar
Cleveland, Ohio
Hi, I'm having some issues displaying faces on my tree. No mater what definition i do pick the tree is full red wher the picture should go. This is an imported sequence to my layout. I do copy and paste the faces folder into the show folder.
My question is; Where the folder should be located so I can select the face definitions?
Normal default face display ok.
LawrenceDriveLights
You will need to define the singing face images to your MegaTree in the Layout Tab
Select your Megatree, scroll down to Faces and add a new face etc.
Dont forget to save after assigning the face images
I did a little video of this for the Blinding Lights Sequence,
It is a similar process except you can use other images for faces which are available to download with xLights.
View: https://youtu.be/zDVMYd-K2XM?t=783
Jorge Bolivar
Cleveland, Ohio
Thanks, I will watch the video in a few and pretty sure will have more questions. Hope not.
