Madko
- Thread starter
- #16
Thanks heaps YL for your input. Was worth another look. I am now considering the P2 but need a bit more reading up to do.
As for the pig tails, is alot of ACL member using the 0.5 mm core size? If so do you know the current rating? As the 12v 2811 pixel strip pulls 3.2amps per 5 meter length. Is this sufficient? Surely the 5v strip that pulls 11.3 amps can't be supplied using 0.5mm core pig tails? Or am I wrong and can you explain or provide a link to explain? Do pigtails come in larger core sizes?
