FPP - BBB - P10 Matrix Issue
Thanks,
That looks quite normal with regards to cabling, as long as the BBB config matches the physical layout then you can confidently move to the software config being the issue, unfortunately I don't have capacity to fire up my matrix/bbb at the moment.
Nothing so far says that the BBB and the panels are incompatible as at least the panels light up, just the config needs tuning.
Question- does it work correctly with only the one power supply that is suppling the BBB. The reason I ask is that I see that the left hand two rows of panels dont have a common 0V (V-) to the right hand two rows which have their 0V (V-) commoned to the BBB hence data has a refernce point
I have given up on the BBB option and moved to working with a colorlight option which has gotten me much closer and I would say I am 90% there but I need some additional assistance getting over the hump. New post with setup is here
