FPP master/ slave mode audio
BluePat
When using FPP on a couple of raspberry pi’s in master slave mode is the audio output by both master and slave or just the slave??
you should plan on using audio from the master only
The Signstek CZE-05 or Retekess TR-508 are pretty much the go-to transmitters. I would keep it where your show player is (FPP/xSchedule/etc) so you can run the audio lead to it, but far enough away that it does not cause interference to the equipment.
