Answered FPP not working with pixelstick firmware
Syd
Gettysburg, PA, USA
I am total newbie with all this new (to me) technology.
I threw together a esp8266 with ESPixelStick firmware and an Adafruit 8 light neopixel stick.
Am able to test using the local firmware. Finally got xLights working and am able to send to the test board using unicast.
Installed FPP on an old version 1.0 PI. Nothing I do will get the FPP to blink lights. The display test is where i expect testing the FPP Pixelstick working together.
I followed a few of the FPP setup videos - each time wiping the config back to just about nothing... Uploaded configs from xLights copied over simple fseq's - all to no avail.
I hope it's not the choice of pi versions - could it be a timing issue from the pie - I have a couple other newer pis but they are doing important stuff i do not want to interrupt.
Any help would be appreciated ...
Can you post screenshots of your Pi, wifi, Xlights configs.
What are you sending the wifi data with? With a Pi or via a wifi router?
I am trying to send from a PI - I can get the lights to work in XLights - but have never had ANY output from the PI.
I flashed some code onto a esp32 that output raw artnet data - tried with that - again from xLights got output - using the same config on the FPP nothing ... Maybe some screen shots will help
I am using the eth0 out back to the router and out to the esp chips
it was plugged into a gigabit switch - i also tried plugged into the back of the router ...
The enable E1.31/Artnet output isn't ticked. I hope that's all the problem is as I know nothing about Artnet or ESP Pixelsticks
  • Like
Reactions: Syd
You appear to be playing with the same things as me at the moment - espixelstrip and falconplayer.
Changing the output definition to E1.31 Unicast should help
It started working perfectly after I ticked the Enable E1.31 /ArtNet Output: - I knew it was something between the keyboard and the chair.... Both ARTNET and e1.31 unicast
Now the hobby is going to get REAL expensive - LOL :)
  • Like
Reactions: AAH
