jediknight2
Just as an FYI, if you are going to follow this http://www.lightuplawrence.net/Home/how-to-1/rgb-dmx-wiring write-up on soldering a connector to the Enttec Open DMX device...it wont work unless you have a VERY fine soldering tip.  They have changed their connector on the board side and pin 2 is BEHIND everything and very difficult to get to.  I have ordered a 5-pin to 3-pin connector, but in the mean time...I just soldered the ends of a Ray Wu 2 wire waterproof connector and stuck them in pins 2 and 3.  Not secure, but it works.  You would THINK that with Enttec knowing this device is used in many different ways they would place a solder pad on the inside to get to...
