Hardware Setup: ECG-P12R video
harrison0550
Chattanooga TN
thanx andy.
i guess i need to develop some new products so you can do more videos!!!
-Ed
Found the right guy to have the hardware. If he would behave a bit more it would help.
Great videos for any hardware. As this is geared directly toward the J1 hardware, this shows the steps in really any hardware that should be taken for setup. Great work Andy.
Thanks guys!
Ed its been a ton of fun shooting these videos. The boards are so well made they make it easy. You keep making them and I will keep hooking them up on camera. The D2 video is done as well. I just need to find the time to edit it and upload. Looking forward to the release of the XCG-X2A. Great work!
William, what you talkin bout? I always behave ;) HaHa if you could only see the bloopers reel of what didnt make it into the videos. Then you would really be laughing.
I also wanted to add a post by Eddy on power that I think will be helpful for those needing help doing the math on powering strings/strips from the board......
ɟɐsʇǝppʎ said:
The ECG-P12R has 7.5 amp fuses for each output and each main bank has a 30 amp fuse, so that means you could safely run 20 12vdc 30 LED/M strips through a P12R (10 on each bank). Now most power supplies come in 350 watts or lower, if taking the 85% power supply rule then you can only connect a max of 8 strips per 350 watt power supply which means 16 total strips using both banks and a seperate 350 watt power supply for each bank. then you can refer to the ECG-P12R manual and check on option 4 and 6 for wiring pixels, these show you how to use additional power supplies.
The loads of 12vdc and 5vdc lights vary depending on the type used as shown here
12vdc 2811 strip - 10 sections/m Strip
7.68 Watts/m @ 12vdc = 0.64 amps/m
5vdc 2811 strip 30 sections/m Strip
7.2 Watts/m @ 5v = 1.44 amps/m
5vdc 2811 strip 60 sections/m Strip
14.4 Watts/m @ 5v = 2.88 amps/m
12vdc 2811 String of 50
(0.3 Watts * 50) @ 12vdc = 1.25 amps per 50 strings
*Note refer to this thread to see the differences between 5vdc and 12vdc strings
5vdc 2811 String of 50
(0.3 Watts * 50) @ 12vdc = 3 amps per 50 string
So it depends on what you decide to use will determine how many can be connected to an output of a P12R to stay below the current limits of the individual outputs and P12R board. Power supply loads need to be considered
that's what we need - an andy's bloopers reel .... i can add photos of pre-production 'smoking' boards!!!
Andy,
Great job with the video's and thanks for taking my calls for help. With video's like this more will start to installed pixels as many are scared of making a mistake on the wiring. The p12r video hits just right for me Sir.
Thanks again,
Jeff
Hi I'm trying to find the info page using pixels with J1 sys ecg p12r pixel controller guide can"t find it
I have it here on my onedrive. Not sure what happened to the forum link....
https://onedrive.live.com/redir?resid=5830318B7C09599D!609&authkey=!ACKy4eY8wxepx_8&ithint=file%2cpdf
