jstjohnz
I have purchased 2 controllers from Ray Wu.  The first was for the 6803-based pixel strips, the 2nd was supposed to be for the 3005 pixel strings.
The ones I am talking about are the stand-alone controllers, with several big red round pushbuttons on top and a slot for an SD card.
Well the first one never worked, just a solid error LED.
The second one, as I said, was suppose to be for 3005s, but instead came congigured for 2801s. It does control a string of 2801s, but all I have been able to make it do is cycle the full string through 7 colors and repeat.
I'm pretty sure this last controller can be configured to do 3005s since it has a 2nd string connection terminal strip with just A B and Gnd. But I suspect it needs a different file on the SD card, since the SDS car that came with it was marked '2801'.
So I'm just wondering if anyone else has one of these and has either figured out how to use it or has gotten some documentation from somewhere.
I really need this last one to do 3005 strings since my plan is to use it to help reverse-engineer that protocol.
FWIW, the file on the SD card for the 2801s is 00_1.led, and it's 1653kb.
Any help most appreciated.....
-jim-
-jim-
