HC-1 P10 background colour issue
Doctor_007
Toowoomba
Hi All,
I've received my HC-1 and a few P10 panels for my stand alone "Tune To" sign. I've programmed a couple of simple sequences but it seems to always have a green background, no matter what I try. Any ideas... @smartalec?
SmartAlecLights
Murray Bridge, S.A.
Hi All,
Ive never come across that issue before..
have you selected the right panel settings an saved them to the usb stick, (could be a issue there maybe)
but for both panels, that rules out the cables at fault.
bbayjohn
Batemans Bay
I can't see the whole pic. It looks like you have HUB75 chosen?
I have my data from left to right
SmartAlecLights
Murray Bridge, S.A.
that picture looks correct, (matched it up with a pic of mine)
after you save the panel settings, do you export the settings to the usb stick?
Doctor_007
Toowoomba
Yeah I saved it then exported. All the text etc. appears on the screen correct sized on panels but whenever there should be a border, a picture or animation on background it just stays green.
djgra79
Cranbourne West
Does that mean that the image type are not supported or anything to do with converting or codecs? Sometimes pc displays are green when the files cannot be converted or displayed properly due to incorrect codecs installed.
Kimbo3000
Ive had this issue too. I got mine working then was stuffing around with the config of the panels and lost my initial setup (my panels arent listed when software installed).
I used my backup from home and it worked fine after that. So I assume its due to wrong configuration setup for your panels.
Good Luck :)
