Answered Help with PixLite 16 MkII and DMX Lights
Discussion in 'DMX, E1.31 & Networking' started by rhys100, Nov 6, 2016.
  1. rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    Hi,
    I have purchased a PixLite 16 MkII, and I have six of the following lights from Ray WU
    https://www.aliexpress.com/item/DC24V-input-30W-RGB-DMX-LED-flood-light-IP66-high-quality-with-15mm-3-core-waterproof/1090185346.html?spm=2114.13010608.0.0.Aybndl
    I have set My dmx universe to 50-54 and ch 1-512 for each as per screenshot
    https://imgur.com/2a6708r
    I have tried wiring via ethernet and also direct with the 3 cables testing via Xlights.
    Screenshot: https://imgur.com/Sr2spIX
    Whatever I do i can't seem to control them
    Am I missing something?
  2. ShellNZ
    ShellNZ Senior Elf
    Jun 17, 2012
    859
    3
    Karaka, Auckland, NZ
    I can only really tell you what I have.
    I have 6 x 30W RGB floodlights running off the 3-pin of a Pixlite4. The floods are daisy chained with 2 x 24v PSU's either side of the house for powering.
    Do you have one floodlight per output??
  3. OP
    OP
    rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    My six lights are daisy chained and plugged into DMX ch 1 only.
    Can you tell me, when you turn yours on, do they flash randomly until given signal?
    Im trying to work out what they are supposed to do when correctly hooked up. They only seem to flash RGB and I have no control over them
  4. OP
    OP
    rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    Here is picture of my setup.
    mkII board - https://drive.google.com/open?id=1RoFdwJks9hJnCRsxl4kqesUIQ5p9ovslew
    plugged into lights - https://drive.google.com/open?id=11NWHj4IF-5vkUKgl4eadBEJCDrdeXtlF8w
    Video of what they are doing: https://goo.gl/photos/UY31J3A59GXTdPGp8
  5. Andy2000
    Andy2000 Apprentice Elf
    Sep 26, 2014
    59
    0
    Cambridge Park
    What dmx channels are your lights programmed to?
    Did Ray pre programme the lights?
  6. Andy2000
    Sep 26, 2014
    59
    0
    Cambridge Park
    From memory and its been a while since i have set up my dmx lights i think each light needs 3 channels so your first needs to start on 50 and your second on 53 and third on 56 etc
  7. OP
    OP
    rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    I am still waiting for ray to confirm. I assume they would be ch 1-16 though.
    I have covered all channels however 1-512 so I don't think it really matters. Did you watch the video of what they are doing?
  8. Andy2000
    Sep 26, 2014
    59
    0
    Cambridge Park
    Normally Ray will set them to 1 - 16 unless you specify. I set mine to universe 1 and dmx channels 1-3 then 4 - 6 etc
  9. OP
    OP
    rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    I checked with him, he set as you have said.
    Do they need to be piggy backed in order of channels or it should not matter? Just perplexed as to why they are not working
  10. i13
    i13 Senior Elf
    Jul 5, 2013
    804
    21
    It does not matter what order you have them along the DMX line. Everything along the DMX line sees the same signal and you can even have multiple items responding to the same channels.
  11. OP
    OP
    rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    any idea what problem is then? :'(
  12. Andy2000
    Sep 26, 2014
    59
    0
    Cambridge Park
    You might need to turn on the output for dmx 1. Looks like its not on in your screenshot
  13. plasmadrive
    plasmadrive Full Time Elf
    Jan 12, 2012
    244
    40
    Elk Grove, CA
    I can't tell a whole lot from your video other than it looks like they are in test mode doing the RGB repeating pattern. That is what happens on most of those Chinese lights when they don't have a legit DMX signal.
    Your slightly plugging and unplugging them is not really helpful and could be an problem. I wouldn't do that a lot.. it is not a valid test for anything that I know of.
    You could have your D+ and D- ass-backwards. Any valid DMX signal would stop the RGB test pattern regardless of what channel the program is putting out data for.
  14. code
    code New Elf
    Sep 22, 2015
    34
    0
    UK
    JuSt remember the gnd from the floods needs to go straight to the psu and a secondary gnd from the board to the psu. This was a mistake made .
  15. OP
    OP
    rhys100
    rhys100 New Elf
    Dec 17, 2015
    17
    0
    North Gosford
    I unplugged the ground wire, and now the lights turn off. However i still cant control them..
    Is there anyway to work out which wires are + - and ground or do I have to guess 1 in 9 combinations.
    Here is pic of setup without ground - https://drive.google.com/open?id=1GkmNyIf0UgQMOVxMfLf4mEfTVgDjkpBO3w
