cwbotner
- Thread starter
- #1
All;
Can I set the LOR controlller ID using the DMX setup, or do I need to purchase the LOR dongle? (I would rather not buy a $60 dongle just to set the IDs)
I understand the Documnet attached to this post, Thank you, but I did not see where it covered setting the unit ID.
1)The slide in the Doc that says to use the software or the onboard switches, but My controllers do not have the switches. i guess I am unsure if I can use DMX to access the software to set ID's or Upgrade software.
2) It states that you cannot use the shimmer and twinkle on the controllers if using DMX... Can you use it in the LSP software? or is it just completly unavalable to be converted through DMX?
3) Is the RJ45 adapter that David_AVP sells for this purpose? to go from the DMX controller (j1sys D2) to the 1st unit? then it is just regular RJ45 pin pattern from LOR controller to LOR controller?
I plan on using 1 port of the D2 to control my LOR controllers, and the other to control my RGB floods, and HolidayCoro products.
Please asssist..
Thank you..
Please asssist..
Thank you..
