Holman Floods wled possible??
Allen
Came across this as I browsed the latest things I don't need, but will buy anyway at the big green kids store. Anyone know of the possibility to hack and run wled or somehow to run them with xlights?
I didn't buy them because if it's not possible then I won't bother and being so new I wanted to ask before leaping.
thewanderingpine
there’s a possibility that you could open it up and find an ESP8266 chip inside that could be flashed with WLED with some very careful soldering. But I don’t think it’s likely.
Skymaster
Crazy elf
Western Sydney
You'd be better off buying standard WS2811 10W floods from one of the known vendors and creating your own ESP based WLED controller. The price would be very similar and you'd know it's going to work.
I thought they were Bluetooth? Does it say wi-fi on it anywhere?
EDIT: it does appear to be Bluetooth only, so unlikely to have an appropriate module inside.
Notenoughlights
400,000+ twinkly lights
Christchurch, New Zealand
I'm betting it'll be one of those little bluetooth solder-on boards attached to the main PCB, most likely communicates with the micro-controller on the main PCB that drives the r/g/b transistors via serial data, you could theoretically use an esp8266 to drive the R/G/B transistors however, but would require you to open these up and do a little DIY work.
Annoying Elf
Christmas Light world
It appears to be 4 pins on the extension cables.
Most likely dumb RGB, with a common anode + R, G, B).
Maybe power + RS485 communication if they are smart addressable lights?
