I need help with configuring my controller
Hi All
I seem to have hit a hurdle, I had my Controller working before when I had it connected to the network, but am struggling running shows through the Pi ethernet out.
Here is what I have configured
  • Gateway (eero6) Local IP 10.0.0.1
FPP on RaspberryPi 4 - Connected to Gateway over Wifi
  • Wifi IP 10.0.0.100
  • Ethernet Ip 10.0.9.100
Genius Pixel 16 Controller - Connected to RaspberryPi with ethernet
  • IP 10.0.9.85
Proxy Configured on FPP to access Genius over the network.
xLights on my MacBook can see the controller and I can upload output configuration to it.
With all this configured, I can't make my lights light up with either running a show from FPP or using Output to lights on xLights. Where am I going wrong?
I have tested using the test mode on the controller and my lights do light up.
This is year 1 for me so Im still awaiting by bulk order of lights, I just have one string connected to port 1 on the controller for testing for now
Thanks in advance everyone,
Looking forward to receiving your help
Nick
**Update**
I have been able to get the output from FPP to work!! YAY!
However it seems the xLights - Output to lights isn't workings still
Needs some help with this one, Im out of ideas
Given you have a proxy set up and working, the trick here is to ensure that the DDP input is enabled on FPP.
Goto Channel Inputs -> E1.31/DDP/etc page and make sure the enable box is ticked. You don't need to have any other configuration for DDP to work.
Unfortunately I dont have an FPP accessible to get the exact screenshots for you.
