Icicle speed issue
Adam V
Hi guys,
Having an issue with 2 of my icicle runs, they don’t run to the beat when going up and down. The smaller return goes the fastest, the lh a little slower but faster than the rh run. The rh run is to the beat. It renders perfect.
Any suggestions would be appreciated. The icicles are in there own group
View: https://youtu.be/23VxYpsHS64
Adam V
Yes. I can’t figure why only the garage operates normal speed. It only happens when they go up and down. It’s gotta be something in the effect. I’m still learning sequencing(this is a bought sequence)
Croydon Lights
I am no expert but could it be because the amount of icicle are different in each side and in 3d you might need to have them at two different groups left and right and adjust the cycle of each group to get them to match
Katekate
Portland, Vic
I thought about the 3d placement issue, and was going to suggest per model rendering to get around it, but they already have per model turned on in that screenshot ^_^
Adam V
After 2and a bit hours on zoom trying and redoing everything, fixing my few errors 🤦‍♂️ we found the issue! I missed the ticking on alternate nodes🤯 on the 2 icicles that were playing up. A small but very important tick. A huge shout out to Mike(Skymaster) in the zoom room. A patient champion!!
