Kitman
- Thread starter
- #31
Yup all power supplies are earthedDo you have earths on the power supplies?
3 core mains to every controller boxAre you running 3 core mains cables or just 2?
3 of the controller boxes are running from the same power point in my carport. The power point is a 15amp power point that was installed brand new by an electrician for my welder. No earth issues with the plug I have metered it to the ground peg all fine. Nothing else is running on this circuit as it is dedicated 15amp.Are these power supplies running from the same circuit in your mains? If so, try switching to a different cct and see if that helps.
You may have inadvertently stumbled on a poor earth in your electrical wiring of your house.
The only thing I can put it down to is interference coming from the icicles lights due to how the signal wire is running down and then back up, perhaps not enough insulation between it and the rest of the circuit and it is causing some weird feedback. It will remain a bit of a mystery I am afraid without the proper tools and equipment to measure exactly what is happening.
