You shouldn't have to replace them all, you may just have a couple of power supplies emitting interference and need to find out which ones are the culprits
It seems to be all of them causing the issue, with the control boxes powered on with no lights connected there is no issues, however as soon as 1 string of lights is connected then it causes issues right away even without any sequence running.You shouldn't have to replace them all, you may just have a couple of power supplies emitting interference and need to find out which ones are the culprits
Shout your neighbour Netflix and Stan for the month.I guess I could cover my house with tinfoil to try and stop the interference from getting to the neighbour's antenna hahaha will keep this updated with the outcome.
They already have Netflix and have resorted to watching Netflix every night after 8pm lol. There is however only so much that you can watch on Netflix before running out of Netflix. Perhaps I should shout them a VPN so they can get the US Netflix which would make them happier.Shout your neighbour Netflix and Stan for the month.
Interested to see what the problem is with this one.
Your neighbours may not have put 2 and 2 together yet, mine didn't for a few days they just thought it was something wrong with the TV or antenna then they started to notice it was every day at the exact same time which is when they asked me. Depending how close your neighbours house is depends if it will be affected and if their antenna is pointing at your house, my neighbours antenna points right at my sleigh on my roof so that certainly won't help, I am going to have to try moving my sleigh power supply etc from on the roof to under the eaves but that may involve a rewire of the sleigh since the cables will need to be quite long and I may then have other issues.Our reception is the same but we haven’t had any neighbours complain about theirs yet. I have a couple of new props this year so set about last night testing which one it was.
Well it turns out my neighbours TV antenna was stuffed so they got a new one. However, I haven't asked them if that has fixed the issue when my lights turn on.Did you get to the bottom of the issue @Kitman ?
