bbayjohn said:I have 2 of these. Given they come pre wired with pigtails, they are very easy to set up and use.
http://store.lightorama.com/rgbfl10wa.html
David_AVD said:[SIZE=78%]Not sure if the E6xx controllers have a DMX output though?[/SIZE]
The e682 does have DMX output:David_AVD said:The controller will need to have a proper DMX output on it to drive the Ray Wu floods. You might have to ask the E6xx supplier about that.
Yea sorry missed the e6804 part of your post.sck1ng said:bbayjohn said:I have 2 of these. Given they come pre wired with pigtails, they are very easy to set up and use.
Will they work with an e6804? or only LOR's controller?
David_AVD said:The page linked to actually describes all of the connections.
mpurser said:on the 68xx if you are runing the new firm ware under chip type set to dmx then wire the xlr connector to the instructions in jim new manual here is a jpg of the pin lay out
Connect dc power to the flood - most likely pink & black wires
