LSP 2.8 Macros
So Still having problems with pressing the save button.
I have uninstalled all 2.5 and 2.8 then installed 2.8.
Hope it can be fixed.
Colin
You need to escalate the issue over at the LSP site, here will only get you so far as on the LSP forum you will get the developers reading the posts.
I have the same issue. I did a fresh windows 7 install and still have the problem once on a while. Sometimes it saves no problem sometimes I get the error. The LSP forum couldn't help because they couldn't duplicate the error on their machines... Kind of a weird one. I learned to live with it
What does the sequencer log file show?
as long as both were not installed in the same location 2.5 and 2.8 can coexist you do not need to remove 2.5 unless you do not plan to use it.
I actually have both installed in the same location and I have not had a issue yet. Granted I am only play with it this year and not actually sequencing a show but I have probably about 20 hours with no issues.
I did make one change and that is I changed the shortcut to start as administrator since it was asking me the question every time I started up.
