LSP and e6804 - no joy
Shanta
Wake Forest, NC, USA
I am having a fitful time trying to setup my e6804 for use with LSP 2.8. I can access the config screen, can run test sequences from the config page and the pixels work. I can run test patterns in XLights. I can run converted sequences in XLights. I cannot control the pixels at all in LSP. My initial setup was as straightforward as I can imagine; 1 universe, starting at channel 1, 50 pixels long. I've tried Multi- and Uni-Cast. I just really don't know what to try next???
Just out of curiosity have you got the output to lights thingy ticked? I'm not sure what it's called and I'm also not sure where it is as I had to get someone to remote into my pc to get it to do the same.
The output is located in the Playback menu, or in the quick access menu at the top left of LSP.
also, ensure you have the outputs configured within LSP.
You have went through output config and also made sure your input is active? I am running a e6804 live now in a show. So its a config thing
