I've been trying to convert my show over to LSP from LOR since LOR's visualizer keeps corrupting my files effectively making it almost impossible to sequence anything and I'm having a huge problem with Macros. Everytime I try to use a macro on a layer the effect will render as it should for most of the channels but then it blurs the effect on at least one or more of the channels/controllers. For instance, I have 8 vertical strips on my house each represented by their own virtual controller in LSP. I wanted to do a simple sine wave effect (half red, half white) from an image I created. When adding this macro to the layer the first 2 controllers, and last 2 controllers look fine and as they should, but everything in the center is just a blurred mess. It happens everytime I try to apply an effect using a macro. Even if I try to do a chase on other layers via macro, typically the last controller/channel will look all blurred. What am I doing wrong here? All channels are mapped correctly and timing marks are in their correct place, but no matter what I do this happens. Any advice?
