Making the change from LOR to DMX and DIY
Last year i started with 64 channels using LOR boards, this was a good starting point as it didn't give me to much to be overwhelmed with for my first year at computer controlled Christmas lights. This year i really have the bug now and started looking at way to bring the cost of my equipment down and at the same time increasing the joy i got from making the display. The answer was DIY, this now gives learning & building electronics a purpose because you are making things that will be very useful to you and save you a lot of money and at the same time it gives you new skills and knowledge and self satisfaction of achievement.
For me i have decided to ditch LOR S2 software and go to Lightshow Pro (LSP), the benefits of this are that all your LOR gear will still work with LSP including the network dongle so you can run a LOR network and a DMX network at the same time. This is much cheaper than using a LOR IDMX dongle (US$259.00) instead LSP is US$89.00 and then you can make a DMX dongle for under US$60.00. Once you have a DMX universe there are so many new options in lighting and control that you can take including Phils great Tiger DMX controllers.
So if you want to get the best bang for your buck, learn new skills and increase the joy and satisfaction that this hobby gives then DIY is the only way to go.
A very good diagram David, makes it a lot easier to see where everything goes, a must view for anyone new to this hobby
Camguy2050
dmoore said:
For those coming from LOR to the DMX world, this map might also help out to explain all the "parts" involved. Lynx is just a standard DMX controller...
http://www.holidaycoro.com/2010LSHWorkshop/Lynx%20with%20LOR%20Cabling%20Topology.pdf
Hi there I tried following this link but it no longer works if some one has a copy of this it would be great as I am new to computer controlled lights and am trying to find out what is involved as the guy Down the road from me won the Christmas lights comps in my area and I want to rock his boat a little just to stir him up as I helped him with his lights this year but he is not into computer controlled lights just led static and flashing displays . Thanks Joel
You can take a look at http://auschristmaslighting.com/forums/index.php/topic,1211.0.html this has some layout diagrams you could use
Also you may find further info in the wiki and in the learning centre
Also the chat room is another good resource
Camguy2050
Thank you these links are very Helpful ....Joel
dmoore
Houston, TX, USA
Joel -
The updated link is:
http://www.holidaycoro.com/kb_results.asp?ID=21
