lightheaded
- May 8, 2022
- Thread starter
- #16
Looks like I typed in the wrong value. I'm going to change that. After I figured it out its actually pretty easy. I'm going to sit down and work on a custom model. I have null pixels in the middle of the matrix which I couldn't figure how to due that.I am not an expert in this, but there are many things that confuse me about your setup. For example, why the 3rd part of the first string starts on channel 299 instead of 289. I also think if you let xLights manage your config this is going to be a nightmare.
I would help you with the custom model if you are willing to try that instead. This gives you the option for xLights to do everything... as you change your layout it will auto-assign universes, configure new props, etc.
I have not personally experienced any, but recommend you try it yourself in xLights (no need for any hardware to try it in layout, sequence to the submodel, etc.)Are there any disadvantages to the sub model approach? Not having to deal with splicing a bunch of wires or ordering custom from china is a big advantage. Do I lose anything in terms of sequencing/xLights/etc?
