Mega tree image duplicated
Dene Hyde
I appear to be having an issue with images/ effects on my mega tree where they are being split down the middle of my tree. It is like I have two 90 degree trees instead of 180 degree. It looks fine in xlights but images are not appearing correctly. I feel like it is a simple setting but I can't seem to get it to work.
Does anyone have any suggestions? Thanks.
merryoncherry
Cherry St., Hudson MA USA
First question I have is if you really started at the top of the tree?
I assume you rerendered. This means the issue is with the controller config, or the way it's cabled. Is it directly on 6 controller ports, or does it use remotes or something?
Did you configure in xLights or manual, if the former did you upload the config to the controller?
Dene Hyde
Yes I have the controller at the top of the tree.
I have rendered and then uploaded to the controller. I have just re-uploaded again. I have just run simple scrolling colours alternating and it appears to still be doing it (difficult to see in sunlight).
I have three smart receivers (only using 2) daisy chained from the main falcon controller by network cable. This is connected to 6 separate ports.
I configured in xlights and then uploaded to controller.
Appreciate the assistance, thanks
merryoncherry
I think you probably plugged it in wrong then. Did you plug 1, 3, and 5 into receiver A ports 1,2,3 and 2,4,6 into B ports 1,2,3? Or did you put 1,2,3 into A1,2,3 and 4,5,6 into B1,2,3. I think the first one is right, second one is wrong, but it looks like what you got showing.
Dene Hyde
Thank you so much, how dumb to I feel now! I have been playing around with all sorts of setting but didn't even think i plugged it in wrong. I suppose that is what you get when you are wiring up in the dark and it is late.
Once again thanks.
