tterbo_1988
- Oct 23, 2025
I’m working on the wiring approach for a new mega tree build and would appreciate some advice from those who’ve done similar setups.
I have used Johnyboys guide as the base of this plan
auschristmaslighting.com
Is it better to:
if power balancing – wiring method
If power balancing, is this approach sound:
Alternate-node method
Alternatively, would it be better to:
What I’m trying to optimise
I can build the controller box to suit either method, so I’m mainly looking for what works best in the real world on a tree this size.
I am leaning towards alternate nodes method
2023 Journey - First display for JohnnyBoy
Hi All, About time I created a post with all that i have learnt so far and how my journey is unfolding. In 2022 i got into the Christmas spirit buying a bunch of standard led lights and ornaments and decorated the back yard. Then in the Boxing day sales this evolved into buying more lights and...
Hardware / Build details
- Controller: Baldrick 17
- Power: 3 × Mean Well LRS-350-12
- Controller box: Custom build, allows flexibility to either power balance or inject
- Tree:
- 32 strands (possibly 30)
- 150 nodes per strand (12 V bullet pixels)
- ~4 m tall
- Portable Hole base with plenty of tie-down points and guy wires
- Topper: Star with ~250 nodes
Planned port usage
- 300 pixels per port (2 strands per port)
- Either power injection or power balancing per port
- Brightness will be limited in software (not running full white at 100%)
Questions
300 pixels per portIs it better to:
- Run 300 pixels per port with power injection in the middle (after 150), or
- Power balance at the end of the 300 pixels and avoid a mid-run injection?
- Controller output goes to a tee at the bottom
- Strand 1: bottom → top
- From the top of strand 1 into the top of strand 2, run down to the bottom
- Bottom of strand 2 back into the tee
- Repeat this zig-zag pattern for the pair
- Use alternate nodes, so each strand starts and finishes at the bottom
- Inject power between strand 1 and strand 2 at ground level
- Keep all power connections low and accessible
- Clean wiring
- Easy fault finding
- Minimal voltage drop
- Reasonable setup/pack-down time
- Long-term reliability rather than absolute minimum cable
