That would depend on the voltage,
24 volts and you require a 3 channel
12 volts and you require 6 channel
because remeber you need to add the voltages up as well for the LEDs in a circuit
if you were running the LEDs individually you would then use 5 volt.
It all goes down to circuit design and the voltage you want to run in
