- Jun 26, 2021
That seems to be a nice size. Honestly, the lower size was dictated by the base ring I found. I thought it would be a bit wider at the bottom but it worked out. It also ended up taller then I thought it would.
As for raising them up, each person has different reasons. Living in the Midwest snow is a concern for me so I raised my megatree but not my small spiral trees. Just finished my first show and when it snowed the lower part of the spiral tree was under snow so next year I will also work to elevate those up also. If there is not major concern I would not raise any of my props unless forced to.How many strings and pixels/string are you looking at for the smaller one? Do you plan to elevate them off the ground at all? Is it particularly necessary to elevate trees like I've seen a lot of people do? I like the relative simplicity and availability of materials with this design. Considering doing a few small ones about the size of your smallest ones for my first dip into pixels. Looking forward to hearing how you like yours and any changes you might make for the future
Going to make some with PvC sweeping bends.Hi Everyone,
My Mega Tree worked flawlessly this season, stable, strong and reliable, I was really pleased with how it held up. My 3 metre high Mega Tree followed the pattern of alot of others, trampoline base, centre pole, steel topper. I've seen the mini-trees available off-the-shelf, like the Dalek ones, though they don't have the density I want.
I'd like to build some Mini-Trees this season, something like the image below, and I think building it the same way, only smaller to my Mega Tree would be the way to go. First problem I've come across is no one makes toppers this small, and trampoline bases don't come this small either. I thought about 3D printing a topper out of ABS, but these toppers when tensioned with pixels strips have alot of load on them and I'm worried it'd snap.
Does anyone have any suggestions on toppers and base rings, preferably steel, for these sections?
It's a Phenolic Resin Panel used in schools, prisons, and building fascades; hard as the hobs of hell to cut.Whats the other material called
