Mounting Chromaletters and tiles.
Renzo1975
Hey guys,
I'm wondering if you can help me out. I got the Merry Christmas chroma letters and I'm trying to work out the best way to mount them together and on my tile roof right at the front near the gutter. I'm trying to hunt down maybe some Bunnings u channel with a 10 mil ID that I can slot the letters into but I can't seem to find any and I'll also put some PVC conduit at the back of it to keep them steady.
I'm sure can use some solar brackets to slide them under the tiles when they're done which is fine but initially want to get them all mounted together all across so I wonder what the best way you guys have found to do. Thank you.
Nice.. thank you...Will grab some U channel and some bolts/ washers and get it hooked up... ta... wiring backwards too since my control box is right next to the last S in Christmas :)
fortunately for you I had to pull all my stuff out of storage on the weekend, so I got some more pics.
the mushroom head bolts come with these square nuts that fit the channel
That is awesome.. Thank you everyone...
Do you happen to know which Bunnings U channel you got? I could prob print some spacers out (to justify buying the printer lol)..
Any reason it's not straight on the coro and using a spacer?
May help me attempt to roof mount too (have to find something to go under the tiles when I'm done lol..
Again, thank you all.
You may wish to put a washer between the coro and the spacer. We had the problem of vibration (wind) causing the spacer to dig into the coro. After we put the washers in, no problem. I believe we used fender washers to spread the area of pressure out.
bolt through with some aluminium tube as a stand off.
hey you dont happen to have the wiring diagram for these letters i have the boysco merry Christmas sign but cant find the pattern to wire it in order for next year when i run xlights ahaha this year they are all ran on dumb controllers so its no big deal but i want it sorted correct for next year
they are all in the download section in xlights, but if you bought from ELD one of his letters is different, the R if I remember correctly. so you will have to get that model from his site.
Yep, used to be called penny washers in the olden days, but we don't have pennies here anymore...
...also known as mudguard washers in the Antipodes. :)
