Walk where the screws are. If you really aren't confident, wear a harness. Just make sure the other end is anchored.franky_888 said:It's in the same section, looks like this: http://www.bunnings.com.au/back-channel-frame-300-x-45-x-20mm-classic-cream_p1010805 (someone probably has a direct link).
In the bunnings I visited it was sandwiched in between the roofing sheets (a little hidden).
Thanks for the magnets tip. That would make build and tare down quicker! Have you got any tricks for buying some courage for walking on corro roofs?
let someone else do it no in all fairness throw a rope over the other side of the roof till it hits the ground find something that is secure or weighs more than you by double and tie it off i would use a carabeener at the least if you dont have a harness andf you walk on the screw heads they will give you grip and i am going to use some off these so i can just clip the conduit onto with out the boltfranky_888 said:It's in the same section, looks like this: http://www.bunnings.com.au/back-channel-frame-300-x-45-x-20mm-classic-cream_p1010805 (someone probably has a direct link).
yeah two storey is a bit different and yes your wife has every right mate i am sure you will find a solutionando1961 said:I have the requirement of placing 3 strips on my roofline but have still yet to figure out how. Lizardking , like your idea, but I have to still figure out how to get pass my wife banning me off the roof. (I live in a 2 storey house too)
