- Thread starter
- #1
Hi All,
When ordering pixel strings from a vendor that are specific to an application such as a mega tree using mounting strip, is it wise to get a custom wire length between nodes?
I guess the same logic applies to a matrix and many other applications and I am thinking every little bit counts when trying to reduce voltage loss particularly with 5V pixels.
If you don't require 100mm centre to centre, would you reduce this? if yes, what would be a good distance for 1" spacing and also 2" spacing?
Happy to be told I am overthinking this and stick with standards if that is the best method.
