Hi all, I have not posted here much but I've been working hard on my christmas light project for a while now.
This will be the first year I'm doing lights so I think I'm not doing too bad although time is rapidly running out!
First of all, I have built 4 X E1.31 64 Channel PWM controllers based on 2 Arduinos (each) and a cheap Ethernet module. One arduino handles all of the Ethernet/E1.31 stuff and the other controls the PWM via shift registers. They talk to each other via i2c. These are for the dumb light strips and some 3W RGB leds among other things.
I have enough strip to outline my main front walls but I'll only be using the dumb strips - I don't have the budget for smart pixel outline this year.
The strips are mounted in polycarb end cap as per https://auschristmaslighting.com/threads/mounting-rgb-strip.1463/page-2#post-12130 but mine are a bit different
Here is a snap of the item details from Bunnings
The 3W RGB Leds are built from individual components and JB welded to small heatsinks. For power, I am using diodes to drop the 5v to the right voltage for the Green and Blue and then another one for the RED. This works perfectly and I have used this method on other projects with great success. I have 20 of these.
These will be inside coro minitrees in my front yard (something like the ones @ HolidayCoro). I was quite impressed by the result of a single 3W LED
View: http://youtu.be/7SMoHMpCcr8
I have also developed an Arduino based Pixel controller. Currently this is only running 20 pixels but it will handle much more than that. With an Arduino Pro Mini and an ENC28J60 Ethernet module, this makes a E1.31 pixel controller for less than $10!
The individual pixels are mounted in a bunch of Solar garden lights - This was a tedious and time consuming process but the result is ok. I bought a few hundred bare WS2812b chips and intend to use more them around the display but I have not decided how yet.
On the shopping list still is some WS2812b strips for some hoops.
Finally, I also have written an app in VB to act as a E1.31 controller too that will display images on a computer screen based on 'channels'. This can be used as singing faces etc but it also supports video. For this, you set up a list of channelx=picture.jpg in an ini file and simply treat it like a normal controller. I'll get some examples of this soon and post it in a seperate thread.
This is a demo of some of the components
View: http://youtu.be/a5w_BCBMmaY
