Newbie connecting DMX2-24
Juddge
Glenmore Park - Penrith Area
Ok so I have connected a dmx2-24 for 28v supply (until my 31v psu arrives )
And I have connected the first 50m string of lights to connector cables 1-2 ( this should be the first cable set )
Now in da-tester
They work fine
Full control
if i go into x-lights - it won’t see it as a auto discovery controller - I have to manually set it as USB
Serial com 7 dmx
When I activate it / it’s gets the greennoght showing it sees something
Test mode in x-lights - does nothing - they stay dead
back to the tester software and works still
What did i do wrong on the usb setup ?
when i run da-tester - i can get all channels to operate
when i press - Output lights - the USB flickers liker crazy - showing it is trying to communicate - however the data lights on the controller do nothing
so i am assuming the issue is between xlights usb setup and the USB
My guess is that you have less than 24 channels assigned to dmx in xlights so it is only sending x channels and the dmx2-24 isn't seeing the full 24 channels it requires so tosses the data and waits for a "complete" packet of data.
Changed the usb settings in xlights to DMXOpen not DMX and it now communicates
I can test all and they work
now to figure out how to add each port to xlights layout - so far I added 1 string 1,1,1 but it keeps using turning on everything
  • Like
Reactions: AAH
so i think i need to close this thread now and open a new one in xlights thread
i create single threas with 1 thre 1 led 1 node -
i just want channel 1 to open to run dumb lights but when ever i do that all lights connected run on the board ?
im using single string - is that wrong for dumb lights ?
i dont hgave any real RBG yet, just dumb kmart and christmas world lights
the 8 settings ones
Exciting but frustrating at the same time
  • Like
Reactions: AAH
