Notenoughlights
500,000+ twinkly lights
unlikely, as you can't "push" current into something, it will only draw what is available. Increasing the voltage will probably brighten the leds, but you may damage something else doing so, so is not a recommended way to go. If you want them bright, you will need to wire them into a standard Christmas lighting 31v adapter.Would increasing the amperage out on the USB brighten the lights?
