roo
Hi,
Not sure what to do. I have just purchased a ray Wu 12V power supply and was told I could connect it with a purchased power cord. I went out and brought what I thought would work a 25m red yellow power cord. Which I found a label on it saying it was 10amp.
Now I was told by someone here that the wiring is L=active=brown mains wire. N=neutral=blue mains wire. E=earth=green/yellow mains wire. V- is the 0V line for controller. V+ is the 5v/12V/24V or whatever for your controller. The problem is I only have 3 wires in the powercord. How would I set it up and also for fuses would I just use a 10 amp fuse?
kind regards
roo
kind regards
roo
