Nutcracker Error
DougieB
Gladstone, Qld
Hi Sean
I am getting the following error since I installed the latest version of Nutcracker, have tried going back to an older version and still get the same result
DougieB said:
Hi Sean
i dont see any error screen?
what error did you see.
what effect were u running?
ill give it a try also
DougieB said:
Hi Sean
I was trying to create a new model ( 2 Arch Single Strand) on local and get the fatal MySQL error after the first screen
Doug
i created a 2 strand target and then connected a single strand effect and did not get the error.
can you duplicate this on meighan.net? That way i can see the data/
thanks
HI Sean
thanks
finally had a chance to test on your website and am able to create the 2 models I wanted. Just seems to be a local install issue. I will try deleting and starting again tonight.
Also with single strand at the moment the colour selection options appears to have disappeared
Doug
DougieB said:
HI Sean
thanks
Doug
there should be no difference between meighan.net and localhost. I did release some code to fix an error in the same process.php routine yesterday. it might have addressed your issue. download a fresh local install and give ti another try.
thanks
DougieB said:
Hi Sean
You cannot have spaces in an effect name. Every prompt says this
"Name for your effect (Up to 25 characters):[/size]This is the name that this effect will show up in your library. [/size]NOTE!! Do not have spaces in your effect name. "SPIRAL TEST" is invalid, "SPIRAL_TEST" is fine"
[/size]
[/size]I have been meaning to get this fixed, it should not be up to you to remember, NO SPACES.
[/size]
[/size]Because you can fix the error, this has not made it to the top of bugs.
So, just enter your effect name as "CANDY_CANES" instead of "CANDY_CANES" and you should be fine.
thanks
Never had a space, that was from the description. The name for the effect was simply Canes2. did not matter what model I was trying to create I ended up with the sql error. seems to be working now though
