bdeditch
First off Happy New Years!!
Ok I am a Newbie when it comes to RGB Light Strips. I have some questions that either I am missing the answer or I just can’t find it anywhere I look. I am running 6 LOR controllers the first 4 are the LOR LOR1602W and the last 2, units 5 & 6 , are the CTB16PC. I am using LOR S3 for my software. I really want to get into the RGB Strips. I have purchased a sample package from HolidayCoro to try out after my light show is over for the season, just in case something happens. I have purchased as well a couple of sample RGB strips from China with a power supply. This is what I have purchased from China:
1 - LED 5050 RGB Strips,36W, 150 LED,5m/roll, DC 12V,yellow FPC,silicone tube waterproof IP65
1- LED 5050 RGB Strips,72W, 300 LED,5m/roll, DC 12V,yellow FPC,dripping adhesive waterproof IP65
1 -Waterproof Power Supply 120W, Input Voltage 110V/220V AC,output DC 12V,10A,
I also have on hand an Enttec Pro, not open, since I know that it is supported by LOR. I have one $6 DMX Module that came with the sample pack from Dave Moore at HolidayCoro, with channel 1 set.
OK here are my questions that I hoped cane be answered
1) How far from the DMX Module can I transfer the signal to the Light Strip? E.G. if I have the module mounted inside a building, how far can I run Cat5E cabled to the before I start losing the signal to the strip. Also is there a minimum from the computer to the DMX Module that a Cat5E cable can be run?
2) Using the HolidayCoro USB to Cat5E cable, from Computer, has lines 1 & 2 used to try his sample pack, LOR uses 4 & 5. I have the instructions to make the X/O to change the lines, but would I be better off making or buying a proper one so I don’t need the X/O . What I mean is buying another RJ45 Serial Adapter and not use the cable from HolidayCoro?
3) Is a terminator required and the end on the run. If I am daisy chaining about 10 strips, should I terminate at the end of the last strip? I seen instructions for making one using a 5 pin plug, is there another way if I am just using Cat5E plugs?
4) Is there an advantage to having the $6 DMX Module already being assigned channel 1? Is this going to cause problems if I am running about 10 of these?
5) Can you use phone line to transfer the signal from the DMX Module to the Light Strip?
6) Would I be better off just getting rid of the Enttec, buying the LOR CMB16D-QC? Am I limited to how many strips I can run off the LOR CMB16D-QC compared to the Enttec? Also does the CMB16D-QC just plug into the last controller like setting up the other controllers?
7) How do you figure out the Max watts a light strip will use, does white use the highest wattage?
I know there is a lot of questions, but I want to be sure I am doing things right, and not having a lot of problems later.
