Opportunity to update (again) my command centre....thoughts....?
Discussion in 'How is your display put together...' started by cdjazman, Nov 17, 2017.
  1. cdjazman
    cdjazman Full Time Elf
    Apr 24, 2012
    292
    65
    Hello all,
    I have been able to get hold of an 18RU 600mm Wide x 600mm Deep Server Rack.
    Wondering if anyone has any thoughts on pros and cons.
    One is to make sure everything is grounded properly (sparky mate to help there)
    I am keen as it is on castors and I can manoeuvre around my garage....oh and lights will make it look cool.... :):):):)
    djgra79 and NTKing(Brad) like this.
  2. tooms
    tooms Full Time Elf
    Jan 2, 2015
    105
    20
    Kalgoorlie
    I went all out with enclosures this year, upgrading from plastic storage containers .. biggest thing I found is I like a distributed setup, I find it easier to have power supply + controller as close as possible to the lights / props .. I'm not sure how these people with 8 power supplies setup in one box operate, but my setup needs a couple of power supplies on the roof and a few more in the front yard and yet another few front of house, so not sure if one big massive enclosure is going to be the go.
    Boof63 likes this.
  3. Roosta
    Roosta Full Time Elf
    Dec 8, 2015
    174
    63
    Hey mate,
    My thoughts would be sure if you like it then go for it! My only concerns to a more open setup would be heat. It should look hella cool lit up!
    Things to ponder.. How will you install the psu's? And controllers? How hard will it be to adjust / rewire as you go? How expensive are the shelves/racks/power rails/fans/etc that may be required to setup your blinky..
    Cheers,
    Nik
  4. OP
    OP
    cdjazman
    Apr 24, 2012
    292
    65
    It has two 120mm fans in the lid...... already to plug and go.
    The power supplies is main thoughts......back to back maybe on sides...?
    Comes with 2 shelves.
    I could use a PDU for the power supplies....?
  5. videoman3857
    videoman3857 Full Time Elf
    Apr 21, 2016
    329
    76
    Glass House Mountains
    Looks like my bar fridge. It has blue lights inside.
  6. JPB
    JPB Full Time Elf
    May 13, 2010
    318
    4
    Glenwood
    I am thinking along similar lines to Tooms, it might be a bit big. I have my controllers and power supplies in 3 locations so that the distance to the lighting elements is shorter, cutting down on voltage drop and null pixel requirements.
    But if it works for your set up then go for it, you could make a very schmick and functional control centre
    Boof63 likes this.
  7. bpj1980 / Boot
    bpj1980 / Boot Full Time Elf
    Jan 6, 2014
    331
    20
    Wadalba
    Not a bad idea, something you could consider is a pull out drawer style setup for the PSU's and controllers, some of the Access Systems we use are starting to give this option so you close the lid and its all secure/tidy, nice look if you ask me.
    It all comes down to personal preference, I like having one big enclosure where most of the gear is, but that being said I do have a second controller for my (Mini)mega tree, last year I ran power to it with multiple cables (around 20-30m away) and just had the P2 in the enclosure which worked great but this year I will be putting a PSU in there to try and eliminate so many cables, I really regret not going bigger with my underground conduit.... should have just gone the whole hog and done 100mm.
    So think what's going to be easy for you to work in and go for it.
  8. ElSalZi
    ElSalZi Full Time Elf Generous Elf
    Dec 24, 2017
    174
    25
    Hedland WA
    I’ve been searching the archives for an answer - did anyone come up with a workable solution to placing the PSUs in a weather proof enclosure close to the different elements?
    I really like the small cabinets in offer from Holiday Coro (CG-1500 Mounting Kit) - but the problem is they’re all the way in the US! Do we not have anything like it here in Oz??
    I’m not keen of using large plastic tube (not that they won’t work, just too big and not UV stabilised)...
    I am trying to see if can get something similar by using Reticulation controller boxes, IF that is possible...?!?
  9. ElSalZi
    Dec 24, 2017
    174
    25
    Hedland WA
  10. MacArthur St Light Fusion
    MacArthur St Light Fusion Apprentice Elf Generous Elf
    Dec 28, 2015
    97
    18
    Moranbah
  11. ElSalZi
    Dec 24, 2017
    174
    25
    Hedland WA
  12. MacArthur St Light Fusion
    Dec 28, 2015
    97
    18
    Moranbah
    Not sure yet... They also do a shallower one... But last year I had my main controller and it's power supplies separate... Would be good to be able to put it all in one. So every expansion, controller, etc could have it's own power supplies in the box with them... See how they look when they show up...
    ElSalZi likes this.
  13. videoman3857
    Apr 21, 2016
    329
    76
  14. Benslights
    Benslights Dedicated Elf Global Moderator Generous Elf
    May 2, 2010
    2,385
    121
    Elderslie
    they do look good Fusion and not a bad price
  15. ComPeter
    ComPeter Apprentice Elf Generous Elf
    Apr 9, 2014
    80
    34
    Townsville, QLD
