Other software ?
Discussion in 'Software Utilities & Other Sequencers' started by BluePiggy, Nov 10, 2013.
  1. BluePiggy
    BluePiggy New Elf
    Sep 20, 2013
    15
    0
    So I got a 16 channel LOR and I have been playing with the sequence editor.
    I am slowly getting the hang of it,.
    My only complaint is I can't seem to start from say the 15 second mark or 1 minute mark for testing. I have to play the whole sequence.
    am I doing something wrong or is there other software I should be using ?
  2. AAH
    3,183
    315
    There is a playback setting that allows a couple of options. Play from start, play visible screen or play selection or similar settings to that. There is also a setting to loop.
  3. OP
    OP
    BluePiggy
    BluePiggy New Elf
    Sep 20, 2013
    15
    0
    So I am an idiot and I can do what I want.
    NICE .
    Thank you very much, This will save me a lot of time.
  4. DanJ
    DanJ Full Time Elf
    Aug 14, 2013
    184
    0
    BluePiggy--click "play" then click on "play range" then drop down to whichever range you want to do. I have used "visible screen" and "from selection" a lot--these both allow you to keep punching away at little bits of your sequence to get it just right!!
  5. Valentinorx
    Valentinorx Apprentice Elf
    Jan 12, 2013
    68
    0
    Long Island
    I use the "Play From" selection allllll the time. I also have gotten used to using the space bar to start and stop the sequence instead of going through the mouse clicks.
  6. Charl Marais
    Charl Marais For my twins was the excuse I started with.
    Jun 27, 2013
    187
    0
    Secunda
    Same - play from selection and start it with the keyboard. It shaves weeks of frustrations 8)
  7. andrewa
    andrewa Full Time Elf Generous Elf
    Dec 22, 2012
    223
    19
    Frankston North, Victoria
    Thanks for these tips, it will save me hours of time.
    I had the same problem and would play an entire sequence just to change 1 bit 1/2 way thru.
    Thanks guys
  8. OP
    OP
    BluePiggy
    BluePiggy New Elf
    Sep 20, 2013
    15
    0
    Thanks guys.
    Next question, can I make a custom shortcut button for these functions ?
