I have the same thing and it has only happened since I loaded version 27. Went back to 25 and no more warnings. Presumed that the developers would correct it soon.when doing a check sequence i am getting a multitude of warnings that HD props have overlapping nodes, I could find a reference to this. Ideas??
any issues with actual output to props ?I have the same thing and it has only happened since I loaded version 27. Went back to 25 and no more warnings. Presumed that the developers would correct it soon.
Haven’t tested on props yet but all appears ok on computer. As others have said on other posts I think it has got to do with sub models within models. Even though it specifies the node number on the exact model I can’t see any errors.any issues with actual output to props ?
does he have a solution? if so do you have a link?I wouldn’t worry about it too much Jarrad. If you have props such as the Rosa Grande or others from GE then they are meant to be set this way. Ron Howard did a video on it recently
No, it was designed on purpose to be that way for some of their effects to come out the way they do. It just a warning and not an error so it is ok and it works fine.does he have a solution? if so do you have a link?
