P12S running 2811 strip
Madko
Castle Hill NSW
Hey Guys,
Im running a P12S with 12 strips of 2811 pixels.
When running my display if i add a sequence where i just flash all 12 strips white then once it goes off in the sequence the lights stay on. Even after i close the program lights are still active high (ON). I have to power down and start the controller back up.Im running HLS.
Has anyone had this problem and know the cause?
First thing I would try is another software package - perhaps David's DA_131 test utility, and see if you get the same result.
This comes up with many software sometimes. Try a 5 or ten seconds of "off" before sequence ends. Seems to fix the problem most often.
Brian
Brian
Agree with you Skunberg, same happened to me with same controller and same pixels, even happened using the testpattern of controller, so what i do now is include"Off" at the end of any sequence to avoid any of them remains turned on.
Ok, thank for this. When you say Off, are you just referring to a section of sequence that has nothing programmed? Or this there a function to switch everything off?
I am also running 12 - 2811 strips with mine. I have a 1 second at the beginning and a 1 second at the end of each sequence where everything is set to off. I found this helps the sequences act correctly. Hope this helps.
Lee
