P2 output loss??
Boof63
Kadina
Hi, have appeared to lose the output from P2 on output one, tested with multi metre and no volts compared to output 2. Tested with lights and da_E131 and confirms it, have looked and pcb but cannot see any problems, (have had experience in overcooking run so I know what to look for) as for rest of it no idea. Attachments below for perusal, any thoughts most appreciated thanks.
boof63 :'( :'(
are you feeding the power to your pixels thru the p2? from the photos it looks that way.
no separate pwr in from pwr supply, just cluttered :D
Now have no output from 1 or 2 as well, will play and see and post back later, thank you coz for the query, it helps to keep the CLAP alive.
cheers Boof63
So are you only running data and ground out of p2? I looked at p2's earlier and ended up going with e6804's. From memory only data & ground should output from p2 and power + ground from power supply directly to string/strip.
Yep Data and Gnd from P2 , All pwr from same ray wu pwr supply, but separate take offs from pwr brick, Need to order another P2 and hope I think.
Cheers Boof63 :-[
