Pixel Megatree
tuppetsdad
Funding & Tech Support
Melbourne
For the Melb Mini will demo a megatree running with some of MPH's pixels strings. Have a half size version under construction for test. Thought you might like to look.
Coolaroo Cross Umbrella base ($20) takes 50mm dia pole and is intended to be weighed down with 4 x 400mm x 400mm concrete pavers (not in the pics). Stand legs fold up nicely to put away.
Top is frame from a 300mm dia hanging basket which Tuppet actually needs for another project
Pole is a 32mm diameter aluminium pool cleaning extension pole ($50). Can extend from 8' to 16'. Surprisingly stiff and will test for general use for our Megatrees this year. Needed to fit a couple of plumbing fitting adaptors to match the pole diameter to the base diameter for $3 each.
Lower ring is made from 16mm aluminium strip.
To check the concept (and because our ceiling is not 16' high) have installed a few pixels strings to show how this can fit together. The strings are doubled over so effective vertical length is 2m. The base ring is 1.3m so for 16 pixel strings (32 vertical sections) would give a spacing of approx 130mm between strings at the bottom. Height of Tree is 8'
For a real megatree we could use 32 strings without doubling them up. Then would have:
Tree Height 4.66 m
Base diameter 2 m
Space between pixels strings at base 0.2 m
Height of base ring above ground 0.3 m
Probably add a few guy ropes as well as the pavers for stability but very quick to install. Pool pole enables other fittings to clip on the top so thinking to adapt a fitting for a star.[/attach]
tuppetsdad
Melbourne
OK so had to assemble and give a try -
Threaded half a pixel string over the top ring and attached the two ends to the bottom ring with cable ties. Then just plug in the 16 cables to E16 and ready to run.
Plugged in an works first time!!
easy peasy :D
Very nice looking mini mega tree, you should be able to get some great effects from that.
I took a different approach to my tree and instead made a spiral tree, its only 2.1 metres high and has 200 pixels (100 for each spiral) so not a big tree but with 2 spirals it can get some great effects.
My spiral tree is a physical spiral tree, thats why i get away with using only 200 pixels. Im sure with some effort you could sequence it in software with a tradition pixel mega tree, or else you could use some extra pixel strings to also create the spiral for your tree
dmoore
Houston, TX, USA
Oh how I await Object Oriented Sequencing - this would make the process of turning a "straight" pixel string tree into a spiral with almost no effort.
mrpackethead
Wellington
Im not waiting for OOS. I've got it now. The scripting engine in Madrix, allows for the "programming" of all sorts of things, including time cued "sequencing".. Its not without effort of course.
dmoore
Houston, TX, USA
Excellent! How much does it cost? Can I also tweak the sequence "on the grid"? Will it require programming or scripts? Does it have built-in abilities to handle the "tight" sequencing such as comes out of SuperStar Lights or is it more light organ type output because I can do that today with video transitions for $89?
Thanks!
David
mrpackethead
Wellington
dmoore said:
Ironiclly David, you probably already know the answers to these questions, but for the benefit of everyone else..
Anywhere between US$420 and US$6000, depending on the number of channels you are going to control
The concept of the time based grid is'nt one that translates into OOS very well. Theres a cue list, which is the closest thing. Ie at 1minute 10 seconds, 13 frames do 'X'
Yes, its programmed, using C type functions which are called. Its not easy, but then the results are spectuactualar. You know what they say, "no pain, no gain"
I think that this example * ( albeit not christmas lights ) shows you how "tight" and smart it gets. Look at 1:00 - 1:20 at the drop tubes. In fact it was from these guys i've learned how to pull this trickery off.
http://www.youtube.com/user/inoageDOTcom#p/u/1/SsqnM_r2bQY
Of course you can make madrix produce so called "light organ" effects. Thats just one of the many things it does. But that would be exploting about 1% of what its capable of.
Thanks!
David
dmoore
Houston, TX, USA
Since it sounds like you are pretty experienced with this - it would be wonderful if you could possibly produce video(s) showing step-by-step, how members of our community could use Madrix to perform these operations?
I've seen a number of "results" videos about Madrix but nothing really on how to, start to finish, setup madrix to sequence for a Christmas display using pixels and non-pixel devices. Maybe this would help to disspell the myth that Madrix is a "color organ" style sequencing application and help others with another option for sequencing their displays.
Thanks for the information!
David
mrpackethead
Wellington
Just putting things back on track. I'm not waiting for OOS, i've got it and using it now. And all the whining in the world won't change that David. You can choose to accept that or not. its that simple.
TimW
Melbourne
Very impressive. Love the 3d effect of drop tubes.
Not sure my christmas display door and bar take will justify the investment this year though!!! (although I liked some of the crowd.... does RGB attract them... or is it the recreational drugs? (put your hands in the air!!!... 8) ))
But a pool rod, inverted hanging basket, an aluminium strip and a few pixels... that is a different matter... much more in my ballpark!
tuppetsdad
Melbourne
So you see Tim we actually are using our pool poles and umbrella bases with pavers this year for our mega trees....stay tuned for our pixel creation.////
